More about the limited
Now i have some time to set down and give a few more details 19,500 is my asking price im located in muncie in,47303 70mm GTQ EXTREAM AUTO,S FRT MOUNT INTERCOOLER 70 mm throttle body and dog house 83 pnd inj.champion fuel rails fully ported and polished stock intake gn1.r heads i purchased them Gary Harman great set of heads with the TDs roller shaft drivin rockers 20 over block with wiseco pistons with a set of titanium connecting rods and a LA BILLET STAGE 2 CRANK modified to fit the 109 block internal balanced, with sfi flywheel and BHJ balancer RJC GIRDLE and oil pan with high volume oil pump frt cover TA. adjustable oil pressure valve all comp cams valve train springs push rods with DLS 218/218 billet roller cam and crower,s solid roller lifters comps double roller timing chain gn1.headers and 3in downpipe with the adjustable boost valve in the car with lonnies extream 400 turbo with a brake and brad co convertor 3500 stall XFI UNIT bought new from HARTLINE PERFORMANCE comes with thump wheel and data loger and all software MSD DIS 4 with 2 step works great 88 thousands thick wall drive shaft built by flame spray in PORTLAND IN, 10 WAY ajd rear racing shocks 90.10s on the frt, new weld draglites 15/10/ with 5 in back space rear frame is notched to fit 10/28 slicks 10 bolt 8.5 in welded axel tubes with mosier spool 3,42 stock gears and ford bearing drivin axels no C CLIP 2 areomototive fuel pumps to support 1200 hp or more you would be shocked when you see the inj duty cycle at 30 psi.now for the body fiber glass bumpers alum. core support rolled quarter panel lips the paint job is ok not a show car looks good but does have a few scratches int is nice no rips or tears good headliner astro roof works great also installed is a anti roll bar with adjustable hime joints the rear shocks are QA1,s single shoot atr stainless exhaust system.I also have a 19 ft open tandem axel car trailer for sale 1,800 for that but a package can made for the car and trailer.thanks
