gunzandgearz
gearzandgunz
 - Aug 24, 2015
Ok Ed Ill try to give you the best advice I can as I don't claim to be the best wrench on the planet but we do a lot of driveability diagnosis in my shop, so here goes. First off do what most of these guys have told you and get some sort of a scan tool as I hate throwing parts at stuff,you would be better off spending your money on the scanner, and finding the root cause of the problem and buying one or two parts and having the scanner for life for future problems,instead of buying five parts and still not fixing it.The filter,plugs,wires, coil,can pretty much be ruled out as the problem because if car runs good at high rpm the problem would only get worse if any of these were causing the problem.The injectors if plugged or dirty can cause tip in problems and misfires at idle and off idle and still run ok up top as pressure increases,but still wont cause high idle condition.As a lot of these guys have already recommended look for vacuum leaks, IAC {need bidirectional scantool for this}to check actual operation and and also need bidirectional scanner for maf operation as you can check it for proper airflow while driving in second gear and checking for proper airflow of sensor.Good luck, by the way most likely cause of your problem imo is vacuum issues as this will cause iac to act screwey and cause hi idle.
