Jan 3, 2017 #1 T TDmkr496 New Member Joined Nov 2, 2016 Messages 28 I am in the process of rebuilding the engine in my 87 Turbo T, what is the correct finish for the valve covers?
Jan 3, 2017 #2 T Turbo Keith TURBO KEITH Joined Sep 16, 2015 Messages 1,671 I had mine bead blasted , used hi temp VHT paint and clear coat . they look pretty good .
Jan 3, 2017 #3 X Ray The GNX changed my life! TurboBuick.Com Supporter! Joined Jan 21, 2007 Messages 1,186 TDmkr496 said: I am in the process of rebuilding the engine in my 87 Turbo T, what is the correct finish for the valve covers? Click to expand... Good for upper intake lower intake and valve covers.......nearest to production finish I have found. https://www.goodson.com/ALB-1-Aluminum-Gray-Last-Blast/
Jan 3, 2017 #4 turbo6mike Mike Ruminski Joined Sep 6, 2004 Messages 1,161 I like to bead blast and paint with Dupli Color engine enamel aluminum 1615 from Advance Auto. I use that on valve covers, plenum, intake and timing cover.
