87 turbo t with 496 project for sell make offer
gnracer1
im thinking of sell my project my 87 turbo t with a 496
motor is in the mechine shop
eagle crank
eagle rods
j/e pistones
2 bolt block
rec head p/p with bigger valves
and a flat tap cam
will need upper valve train
87 T-type Roller, rust free. The car has brand new BMR suspenison on rear. The interior is in good condition. The car does not have the a/c installed, but can be re-installed easliy. The car also has aluminum core support. It has been switched over to vaccume breaks. The car has a Token 1 peice bumper and air damn. There are only a few of these made. It also has aluminum drum breaks in the rear. All the car need to run is a motor, transmission and wireing harness. Was building a big block for it but ran across a F Body, so this car needs to go. It is a TRUE turbo T vin7. The car comes with Pro-Stars. Make offer and we will go from there.
car is in brandon fl
this is the motor be going to the mechine shop
