88 Formula TPI F/S
Vsix
88 Formula hardtop 64k orig miles fresh custom Viper blue paint 91-92 rear spoiler all new weatherstripping new windsheild PA insp 305 TPI eng runs flawless fresh tune-up plugs wires cap rotor MSD coil UD pulleys COLD AC 160 T-stat new hoses ZEX nitrous wet set-up 125HP 10lb bottle painted to match the car (viper blue) stock trans shifts great stock 10 bolt rear new brakes weld in subframe connnectors NEW Dynomax catback exhaust ...NEW 16" black Hot Wheels & tires BFG drag radials ....Super clean gray & black interior CD head unit many new parts turnkey car ready to DRIVE $6,000 obo must see in PERSON.... SERIOUS ONLY PLEASE Call for details
Thanks Jim
215-669-1696
$5,000 Very NICE car great daily driver over $10k invested must see :smile:
I will also include this built shortblock for $1,000 it was built for this car and is all NEW if you buy the car
89 2 bolt 350 bored .040 over (357) 1 pc rear main block
New Scat crank
New KB hyper pistons
5.7 reconditioned rods New ARP bolts
New rings & bearings
New cam bearings & freeze plugs
New Howard hyd roller cam 280/292 dur 504/504 lift 112 centerline
New hyd roller link lifters
New Comp Cam double roller timing chain
New Alum timing cover
New balancer
New HV oil pump & pickup w/steel shaft
New Moroso oil pan w/1 pc oil pan gasket
New flexplate w/bolts
Balanced rotating assy prof built ready for your topend over $2,800 invested
Thanks Jim
215-669-1696
