Valvetrain noise isn't usually in the range of most knock modules. I run knock sensors on over 90% of engines since most are 93/alky. On really high power applications with race fuel I've yet to ever see knock retard even when the esc is 100% stock. Just because there's not knock retard doesn't mean your in the safe zone. It's very possible to overheat cylinder without detonation.At close to Zero lash do you have any issues with knock sensor going off ?? Do you run the knock sensor on your HP builds?
