89 TT/A parts wanted
dsmith4994
i am looking for the following parts for my TT/A conversion
1) Original headers and crossover pipe
2) original Fuel Lines - both of them
3)ATR 2.5" mandrel bent downpipe or 3" terry houston internal wastegate downpipe with flex pipe or let me know what else you might have
4) Orignal boost gauge tachometer
email me with pics and price to dsmith4994@aol.com or PM me....Thanks.....Dave
I have a complete clutser .complete engine wiring harness .I have headers and cross over ,new heads that have to be set up.these are not factory tta heads ,valve covers, ac lines ,spohn torque arm for 200.factory cross member,factory down pipe,hr engine mounts and 3 inch exhaust bunch of brackets. how much money do you have.because that is an expensive conversion. also have a 89 formula350 that was gonna be my conversion for sale. some rust issues on floors and and surface on quartera and doors. I would like to sell as a lot .
Hi..
I have a custom 2.5 DP.
75 bucks shipped
Joe
Fuel lines if you mean the return and feed attached to the fuel rail I sent a OEM set to Classic Tube - PreBent and Custom Stainless and OE Brake Lines and more... and had them reproduced about two years ago ... came out great and they can do them in either stainless or OEM material (I got the stainless on my TTA) ... I also had them do the power steering cooler line that runs in-front of the radiator ... and another TTA owner on here had them do the transmission cooler lines (I got the stainless lines on mine) ... they also do (same as for the GN) the power steering hardline (pressure side).
re: other parts wanted
I also need the smaller of the two alternator brackets that attaches to the headers, Overflow blanket, Cat converter hanger / bracket. I have most of the other parts already.
I have a houston dowmpipe that has been jet coated that will be coming off soon. P/M me
re: still looking for a set of TT/A headers
Still looking for a nice clean set of TT/A headers and the overflow blanket. Any leads on the headers would be appreciated if you know where a set is......thanks.....dave
The coolant tank heat shield has been reproduced.
Go to Gbodyparts.com. They carry it.
re:overflow blanket
Found it at
GBodyParts.com Online
Turbo Trans Am (TTA) Overflow Reservoir Heat Shield Blanket $95.00
Still looking for a clean set of headers preferrably with an ATR crossover pipe
Thanks.....Dave
