All thats left to be done is paint housing and hogs head then assemble and she will be ready to go in. Pretty simple just machine hole in caliper bracket to 3.150" fabricate 2 1/8 inch shims same OD as the bearing. Then drill plate to new pattern and your there. And you will have to make new brake lines, weld a nut on housing to hold T-block for brake lines and weld on a couple of clips for brake lines. Thanks TTA850
