91 GT
10 pt Moly cage
3550 Tremec Trans
Blowproof Bellhousing
Centerforce Clutch
Indestructible Rear
8.8 Ford
4.30 Gears
33 Spline Axles
Spool
Suspension
90/10 Struts
Competition engineering adj rear shocks
Eibach Drag Springs all around
Mega Bite Sr adj Lowers
Metco Dbl Adj uppers
Spherical Upper Bushings
Re-enforced Torque Boxes
Moroso Trunk Mount Batery Kit
With Cutoff switch
Misc
190lph fuel pump
MSD 6AL w/2 step and Multi Step Retard
Nitrous Express Single Fogger Kit with Purge
10 lb bottle
G-Force 5 point harness good til 2006 July
Window Net
Alum Driveshaft
Drive Shaft loop
Kirkey Drag Seat 1 not installed
Motor
Stock Heads Cam and Intake
65mm TB
75mm Mass Air
1.6 Rooler Rocker / 1.7 rollers on Exhaust side
BBK 1 5/8 Longtubes
H-pipe
Brola XR-1's with Turndowns
Weld Draglite
15X3 and 15X8
165r-15's in front
28X10-15s ET Drags
12.53 On motor.
11.15 on bottle
Through in a nice heads cam intake motor and the car would fly.
2900 lbsw/o driver
$6000 obo
Greg
703-300-7718
10 pt Moly cage
3550 Tremec Trans
Centerforce Clutch
Indestructible Rear
8.8 Ford
4.30 Gears
33 Spline Axles
Spool
Suspension
90/10 Struts
With Cutoff switch
Misc
190lph fuel pump
10 lb bottle
Window Net
Alum Driveshaft
Drive Shaft loop
Motor
65mm TB
75mm Mass Air
BBK 1 5/8 Longtubes
H-pipe
Weld Draglite
15X3 and 15X8
165r-15's in front
28X10-15s ET Drags
12.53 On motor.
11.15 on bottle
2900 lbsw/o driver
$6000 obo
Greg
703-300-7718
