92 plymount voyager electric fan wiring question?
wiked87gn
Banned
found me a 92 plymount voyager electric fan, this thing fits perfect on my GN , the fan measures 16 inches with 8 fins S angled, the shroud measures 26 inches in lenght and 17 inches in width, and it covers the whole radiator, the fan is also an inset fan (it does not stick out at all) my questions is, there are 3 wires going into the plymount fan, and I noticed the stock one on our cars has only 2 going into it but before the resistor there are three wires, how do i wire my new chrysler fan so that it works on high and low speeds when needed? btw i have an high low switch installed in the car already. thanks for your help.
You can probably test out the fan directly from your battery.
See which terminal runs the fan on high speed, connect that terminal to the high speed relay and connect the other terminal to the low speed relay.
I am guessing that this fan has a built in low speed resistor ???
