luisturbog
UNDERDOG HOT AIR !!!!!!!
- Mar 30, 2007
I was wondering if anybody had the info on upgrading to "A" body 12" brakes! ???
SignUp Now!I was wondering if anybody had the info on upgrading to "A" body 12" brakes! ???
what brake hoses did you use?I did it to my car. Its b-body/f-body brakes, NOT A-body .
MAKE SURE THE DONER SPINDLES ARE FOR MID 80's B BODY ( caprice classic) 12 INCH BRAKES. Some had 11 inch brakes and wont work . Make sure they come with the backing plates.
You need the Hotchkis upper a -arms part #1101C
70-74 f body caliper. napa # CAL SE4610 for right , CAL SE4611 for left
70-74 f body caliper bolts ( 2 packages) napa UP 82203W
70-74 f body pads napa # UP UP728A
90 camaro 1LE brake rotors (2 each) napa # NB 4885994
90 camaro inner bearing (2 each) napa# BRG BR6
90 camaro outer bearings (2 each) napa BRG BR34
90 camaro oil seals (2 each) napa NOS 19984
90 camaro dust caps (2 each) napa BK 7302438
85 caprice spindle nuts ( 2 each) napa BK 6301523
Hope that helps.
Here is a pic of the stock brakes next to the 1LE brakes :
I've got a set I'm not going to use if you're interested. The rotors you want are off the 3rd gen F body with 12" rotors and the caliper is the standard large GM B body one. You can use the stock brake hoses.Thanks for info! Will try finding those spindles! Hopefully not to hard to find! U wouldn't happen to know the casting # on them just in case I run in to some at the junk yard that have been stripped of the rotors.
Ok! So I'm not limited to the early f body caliper? B body caliper from mid 80's caprice would also work? & how much are u looking to get for those spindles?I've got a set I'm not going to use if you're interested. The rotors you want are off the 3rd gen F body with 12" rotors and the caliper is the standard large GM B body one. You can use the stock brake hoses.
The only difference in the F body 12" rotor and the B body rotor is the bolt patern. The F body has the same bolt pattern as the G body cars so it's a direct bolt on.Ok! So I'm not limited to the early f body caliper? B body caliper from mid 80's caprice would also work? & how much are u looking to get for those spindles?
Took a little longer than I expected to get the pics for you but here they are. No dust sheilds unfortunately but no stripped threads and you can see where the ABS sensor was in the pics. The shafts have heater hose on them to protect the threads on the studs.Pix would be great
