A/C Compressor Bracket Install Questions
pmcgrath
Just finishing installing heads & cam and am in the process of putting the a/c compressor bracket back on and am having a bad attack of memory loss. I can't remember which bolts go where. I was wondering where the bolts go that bolt the bracket to the heads first and how many are there( prior to bolting other accessories to the bracket). I'm trying to avoid getting into bolting the bracket on and then realizing that a different bolt goes through something else first before bolting on to that location. If this confuses you, sorry. I guess any suggestions are appreciated. Any and all pictures would be welcome as well.
Thanks,
Paul.
I took a bunch of pictures of mine as I was taking the engine out. I'm not sure if they'll help you or not, but they're here:
http://www.turbojimmy.com/gnpage.html (there's a link there somewhere)
I just swung my compressor to the side. The "y" bracket is still bolted to it. There's a stud that sticks out of the accessory bracket that the compressor slides onto, and then a bolt in the front and one or two in the back. Sorry can't be more specific. Me thinks I'll be asking the same question in a few days - I get the motor back on Tuesday.
Jim
