I have an 86 Gn with the Electronic Climate Control. When I bought the car in October 06 the A/C worked fine with R-12. Since then it has leaked out due to me just putting pressure on the lines and it seeping out from working under the hood. I did nto operate the A/C for a good 4-5 months now. My wife has had enough of the hot air
I have replaced the drier and orifice tube. I pulled a vacuum on the system with good results and started the car and activated the A/C. The compressor will not kick on. I jumped the pressure switch at the dryer (didn't work) and was filling the a/c w/ R-134. the system would not take much of the R-134 at all since the compressor was not kicking on. I checked the pressure switch and it does have 12volts running to it. Where else can I check to see if the compressor is bad? I have tried jumping the pin on the ECM and played with the switch on the back of the compressor. Is the only power source to the compressor the little plug in behind it? I have also replaced the a/c compressor relay with no luck. I just want to make sure it's the compressor that's bad before I go spending $170+. Any help is appreciated!!!
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
