SignUp Now!Mine would run hot n cold, AC shop tech said freon was ok, needed new accumulator. After replaced accumulator (the're cheap but gotta evacuate system & replace freon) it kept cycling & AC tech said was low pressure switch. I got installed new switch from NAPA (easy fix, it only looses a smigon of freon replacing it) & now runs great & very cold. Counter jockeys don't know parts, so take original switch in as there are different types. Oh, while I was monkeying around I replaced the evaporator (also cheap but a tedious job getting it out of that damn plastic box, then resealing it back up. But, I highly suggest it because you get to see how corroded & narsty they get). It's now in the mid-high 90's here (but low humidity) & it works great. System was previously converted to the newer freon. Cheap & easy try is to put on a new pressure switch. Good luck.
Where did you get the new Evaporator from? Was it correct for a TR? I could not find a NEW Evaporator that was correct for a TR.
Thanks,
Guy
