3.8TransAM
- Apr 8, 2004
Can someone tell me how they AC lines were routed along the fans? Remember at least one bracket, or so I thought. Trying to get it all back to original appearance during the reassembly.
The wire harness fusible liniks and main starter power feed loop under the nountsd towards the oil pan and to the starter utilizing the rubber lined clamp on the block, correct?
Main alt. feed line also drops along with the other harnesses but splits off and across the front of the oil pan and then back up behind the accesories to the alt?
thanks guys
Jeremy
Almost there, if i ever get an actual days worth of daylite to work Im done
thanks guys
Jeremy
