A/C venting question
turbo96max
I took my car to a shop bc the ac was not too great. They found the external vent was staying open and hot air was leaking in. so they permanently sealed it. But now i notice that my glove bos gets cold like a fridge. Also do these cars always blow air from under the radio vents all the time? or it there something wrong there too?:confused:
Mine has always blown under the radio regardless of the setting.
There's a "flip" back below the radio that closes when heat is not in use. The foam that seals that flap deteriorates, comes off, and much air passes around it. I glued a piece of foam to the flap - 90% cure.
