54Rich
- Apr 10, 2007
Just got the car and already upgrading stuff. Anyhow, I have the following:
I'll post a price with out shipping, but most is BO, so if you need it/want it step up and lets talk.
1) B&M Mega shifter, this is out of my T, complete, I'm going back to stock. It needs a new boot. If your going to put it in a T type, then I also have a modifyied console top, so you don't have to cut yours. Shipping would depend on if you took the top or not. $100 plus
2) 87 T gas tank, Perfect except for the dirt that sat on the seam and caused a pin leak. It's been repaired. $25.00. I'll ship if someone can tell me how, it still has some gas in it.
3) 2005 Chevy Equinox 17" Aluminum Aloy Rims, 100 miles on them, with lugs and caps. $400/set plus
4) 1969 Five Supersport wheels with 4 trim rings. One is dented on the back side, good for the spare. $150 plus
5) Lower crank 455 pully for air, #1375143 $20 plus
6) Nice 69-69 gas tank. Someone had put a drain in it. $75.00
7) T type stock fuel pump $35.00 plus
8) 87 Intercooler Bracket drivers side $25.00 Plus
9) 69-?? Ignition Lock $20.00 plus
10) 1 Set 69 chrome wheel chrome someone put mud flaps on the car, so there is a couple of extra holes $100.00 plus
11) 68-72 gas tank straps $25.00 plus
12) 1972 GTO front light bezal complete, not perfect but OK, $25.00 plus
13) 1972 Buick 455 dist. needs to be taken apart and cleaned #1112110 date 2L 29 $15.00 plus
14) Hitch receivers fits Class 3. First one is a 6000lb, 4" drop/rise, 2" ball. Second is a 5000lb, 3" rise/drop, 2" ball. Third is a tri ball straight, 2 5/16" 10,000lb, 2" 10,000lb, 1 7/8 6000lb. With one key lock pin and one 2" trailer lock. $50.00 plus
15) WEN ramdon orbit 10" detail buffer with bonnets and case. $15.00 plus
16) I have the Kenn Bell cold air kit, well most of it. The air dam, the long hose, the filter container. All except the filter for it. The air dam is on my car and is not perfect, the hose is used but good, one clamp and the filter container looks like it was never used. $100.00 plus
Thanks,
Rich
Thanks,
Rich
