Jackie grabos
- Feb 2, 2011
Have my first 87gn, got a few questions. Is it normal for the transmission to downshift kind of hard when coming to a stop for approximate 50mph? It only does this when stopping from higher speeds. I'm guessing the power steering pump needs to be changed because when I hit the brakes or turn the wheel it whines although there is no slack in the wheel. I have changed fluid twice and it is still doing this. My boost gauge on a pillar does not work although it has power, what is most common cause for this? Thinking the vacuum line? When I'm facing the car from the front, do I turn the screw on waste gate arm to the right or left on the turbo to increase boost? Thanks
