About to install roller cam, ported timing cover and crank hub ?'s ---
alwayscode390
I was wondering while I am in front there with the cam swap ... should I go with a ported high volume timing cover, and replace the stock crank hub/balancer with a new stock crank hub/balancer?
With other engines I know that the crank hubs/balancers can come apart ... and these are pretty old parts.
I also read with the timing cover the cam button can wear on the timing cover ... so I was thinking of replacing it when I found out about the modded covers.
Weber has one , and TA has one ... this is my first time in a buick engine like this , is the oil pump part of the timing cover? Is that what is modded to be "ported / high volume"
Who sells new replacement stock crank hub/balancers? Who else sells modded covers? The price difference in the two companies above is $150!!!
Thanks for the advice and help :) ---
From my limited reading on the subject of front covers, the TA cover is reportedly the best bet. It is inspected & prepped to avoid any of the alignment issues that the cheap replacement covers have.
Good luck
~JM~
I have been hearing good things about the TA covers too. Now I just need to know if its worth it for my setup or not.
I talked to a vendor and they told me if I have good oil pressure now , dont mess with it ... BUT is that the only gain you get from a modded cover, better pressure? ---
I'm afraid I can't help you any further with this subject. Hopefully someone else more knowledgeable will jump in.
I think I'd be tempted to keep your stock cover if you haven't had any problems.
~JM~
