ABS fillers?
Ryan
CEO/Founder Nakslist.com
Are ABS fillers the same as factory fillers? I always thought the two choices were ABS or Fiberglass. I assumed the ABS was a factory type material. Is ABS better than fiberglass?.....let me rephrase. I know fiberglass will last the longest. I am worried about spending a lot of money trying to get fiberglass to fit right and look good.
Get the glass fillers, ABS is hit or miss. Also if you get tapped the ABS are going to crack and fall apart, the glass ones will have a better chance of getting repaired. Dancoreproductions.com has the FG fillers
