ac delete panel
84 Sleeper
Has anyone ever worked with the Ac delete panel from gbodyparts. The instructions are not that great and wondering if anyone has any tips .
tips like what?
the instructions should read...
use sealer and bolt it on
cant see what else needs explaining
and i see you are new here
best approach to getting an answer would be to call Brian directly and ask him
If it was only that easy I wouldn't be asking the question. I am talking about the mods to the blower housing and the vent for the blower but I will give him a call thanks
you posted on an ac delete panel , thats a flat peice of aluminum cut to cover to the opening in the cowl when you pull the ac box ... or did i miss something in your OP
There's also a part to purchase (if you need it) that extends the drip rail on the lower windscreen above the delete plate. The delete plate does not come with it.
Brian will help you out.
