Ok I pulled off the valve only a small amount of refrigerant came out. Put the new one on. Seems like I keep chasing the adjustment all over the place. Just to clarify.... is it counter clockwise to raise the pressure cut off and clock wise to lower it? Seems like the pressure is correct (25 psi) when the car is warmed up. But if I run it for a while it jumps to 45psi. My gauge may be garbage..... its just one of those gauges from and empty can of do it your self refrigerant. I also have one of those tire gauge looking things...... but it says hi press on the side..... not sure how to use it.
