Accufab 70MM TB - Take $525 for the Kit, includes Plenum and relocated Air Temp Sensor, IAC Sensor, IAC Relocator Bracket, Custom Vacuum Block with Fittings, and TPS
-SX Fuel pump 18207
-SX fuel Stainless Re-useable element 41102
-SX Fuel Filter Housing. 41002
-SX Fuel Regulator 15404 Black - With Fittings in photo
Caspers - HD Pump Relay
Fuel Pump Trigger Tap
SX Set Up $725 For above It includes the An-10 Line from the rear of the car to the Front, and the AN-12 line from the tank to the Fuel pump. Also the merge fitting for the Fuel Filter to the Pump. All Part Specs can be viewed Below. Over $975 invested with the lines and fittings
http://www.fluidsystemsengineering.com/parts/home.php?cat=100
-Meziere water pump and Relay Take $330 http://www.jegs.com/i/Meziere/680/WP125-S/10002/-1
-200 amp alt Take $350 With RJC Oulley, Fan and Nut -
RJC Racing Under drive Pulley - $125
Champion Alternator Bracket - $200
Stock Coil - Tested and is perfect - $75
Turbo Bracket $25
Accel High Out Put Coil - $100
TA Stainless Headers with Cross over, Stainless Gaskets, Turbo Ceramic Black Coating over $1300 invested - Take $900
Aluminum Rear Bumper Mounts - $45
LT1 Starter $75
Ceramic Coated Starter Shield - $25
4 Inch Cold Air Polished Aluminum- $225
Valve Spring from Champion Heads, NEW never used - $75
GN Custom Ultimate Fender Cover with Case and Grand National Logo Screen - $200
See it here http://www.specialadditions.com/proddetail.asp?prod=UFC
NOS Ignition Module with Plate, ground, and Mount Arm - $235 - Just bought this ignition module NEW.
GTQ 70 Limit Engineering - $925 - Comes with 2 Actuators Heavy Duty and Stock, Oil drain and feed fittings, as well as an AN-10 Line to drain to pan and AN-4 Feed Line
The wheels are 15x9 The inside depth is 5 inches, outside 4 inches.
Tires are M/T 10.5 x 28 -15s - http://www.jegs.com/i/Mickey-Thompson/672/3055S/10002/-1?parentProductId=
Tubes - http://www.jegs.com/i/Mickey-Thompson/672/9553/10002/-1
Wheel Are Convo Pros - Older Version - 5 Screws each Side
Entire set up cost me $1000. Take $600 Tires are Still 80% - Can send more pics
Stage II block also - See it here. http://www.turbobuick.com/forums/threads/stage-ii-3-8-bms-block-for-sale.377737/
PM With questions or Call 859-312-3184. You pay shipping and paypal fees.
-SX Fuel pump 18207
Turbo Bracket $25
LT1 Starter $75
