accumalater
K
kevin
Guest
my 4500 mile 2004r has been giving me problems from 1st to 2nd.and gm says it shifts ok.line test shows ok,my question is i pulled the accumalater out and was wondering if you should be able to move it up and down or turn it in a circle?
both accum and below the seperator plate move up and down/in and out and spin in the housing. What is the problem to have you wondering/looking????
it was shifting real soft and very long to 2nd.i found the problem,the sring in the tv was not stiff enough and the shaft was sticking.still not as hard as i like but it does shift quick now
