activate audio clip at startup
orion
how could i get an audio sample to play right after/ 5-10 after i start the ignition, has anyone heard of this?
If you want it to play the same sample every time you start the vehicle, you can probably look into one of those old Nickelodeon yakbaks or whatever those things were called.
Basically a mini-recorder that could store a few seconds of audio in a digital format. Rig that up via relay to the ignition, and you might be able to do it.
I'm not sure about getting it to go through your speakers, unless you tapped into the output on the yakbak itself, upped the power and fed it through the AUX input on your HU or something.
Otherwise you're stuck with a fairly low-fidelity mono sound from the yakbak itself.
There might be other mini digital recorders worth looking at that sound better, but I haven't really seen any (or looked, for that matter).
If that's what you're trying to do, good luck with it.
Widge
good call man, very creative. idealy, a headunit with an external input would be great. that way i could rig it up nice and easy, i want to get one to also so i can plug in my laptop and play mp3's
