actuators
Velon
Will a hd adjustable actuator from a te60 work on a ta49? Could you make new holes if you had to? Appears that holes are in different places.thanks
You will need to make new holes or grind off the existing bracket if its welded on. Post a pic of the actuator so we can tell you what to do.
thanks for the reply, I have a ta49 actuator to try to duplicate.thanks for the help.
