ShaunKris
#PROJECT84FORIA
- May 13, 2018
Is there such a fitting that can adapt inverted flare hard factory transmission lines to JIC/AN fittings for PTFE hose?
The reason for asking is that I am installing a new transmission with new flex PTFE braid hose with JIC/AN fittings. The inlet/outlet on the Coldcase radiator are 1/8pipe and the only 90degree fitting that will fit is the brass 90 nptf to (5/16 nut) Inverted flare(tube)
. I have the 90 degree pipe to JIC/AN but it sticks out to far and interferes with the a/c condenser.
Any ideas / help would be appreciated.
