- May 25, 2001
Parts are used unless noted. All priced without shipping costs. PayPal to Friends and Family or add 3.5 % More or different pics can be furnished . Most 86/87 years. Contacting by email or text is good. Parts in 73115 area OKC
awkendal@swbell.net 405 831-5195
Austin Kendall
Chrome front fender marker lamps, set. 5974210,209 , GM NOS out of wrappers unused -----------------------------------------------------------------------------$85 set
Stock turbo cover used, uncut, un-coated----------------------------------------------------------------------------------------------------------------------------------------------------------$75
3- stock breather tubes, valve cover to turbo-----------------------------------------------------------------------------------------------------------------------------------------------------$50 ea
Cat hanger complete------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------$75
2 sets chrome bumper bumperetts -------------------------------------------------------------------------------------------------------------------------------------------------------------------$50 set
4 GN wheel centers 25525651 NOS in GM boxes--------------------------------------------------------------------------------------------------------------------------------------------- $275 set
Power steering reservoir, new NOS ,25531140--------------------------------------------------------------------------------------------------------------------------------------------------$185
Delay Relay 25527402, new NOS-----------------------------------------------------------------------------------------------------------------------------------------------------------------------$135
Left door handle 20454213, NOS GM----------------------------------------------------------------------------------------------------------------------------------------------------------------$75
AD-1 Dention Dectector Module NEW in box-----------------------------------------------------------------------------------------------------------------------------------------------------$40
Rubber elbow 25526950 , new GM for PVC breather tube?-------------------------------------------------------------------------------------------------------------------------------$10
AC/Alt "tree" bracket ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------$60
AC "Y" flat bracket-----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------$40
2 sets spare tire hold down pieces J bolt,plastic hand nut, large washer-----------------------------------------------------------------------------------------------------------$20 set
2- correct spare mini tires T155/80D16 shipping would be ugly-------------------------------------------------------------------------------------------------------------------------$75 ea
Black rear view mirror has window mount tab and set screw. Day/night settings original use unknown ----------------------------------------------------------$35
Kirban valve cover breather/oil fill. Older style full polished alum body nice------------------------------------------------------------------------------------------------------$40
Plastic IC fan with 3 bolt mount 25526398---------------------------------------------------------------------------------------------------------------------------------------------------------$40
24 ea Gorilla lock lug nuts, chrome 12MM x 1.5 . All lug nuts are locking type--------------------------------------------------------------------------------------------------$ 25
Fuel injector harness 1984/1985 -----------------------------------------------------------------------------------------------------------------------------------------------------------------------$30
Numbered ignition wires with aluminum, spark plug boot covers. A wire or two show some chaffing ------------------------------------------------------------$40 set
2 floor shift assemblies, no T shift handles with stock shift gates---------------------------------------------------------------------------------------------------------------------$125 ea
2- Transmission dip sticks and fill tubes. One has the hold down tab opened up see pics--------------------------------------------------------------------------------$75 ea
Heater manifold assembly complete has hoses, half union, and control valve.--------------------------------------------------------------------------------------------------$100
Heater manifold assembly bare---------------------------------------------------------------------------------------------------------------------------------------------------------------------------$40
Vacuum block on T body, billet aluminum 5 port, with screws no gasket------------------------------------------------------------------------------------------------------------$35
Upper control arm rear bushing heat shield---------------------------------------------------------------------------------------------------------------------------------------------------------$20
Stock upper plenum some internal porting and opening enlarging, EGR REMOVED--------------------------------------------------------------------------------------------$75
Stock upper plenum 25525146----------------------------------------------------------------------------------------------------------------------------------------------------------------------------$125
Window molding clips plastic 30 ea, fits G body and more----------------------------------------------------------------------------------------------------------------------------------$10
Stock turbo bearing rebuild kit, probably from John Craig?---------------------------------------------------------------------------------------------------------------------------------$50
Bolts for factory rear spoiler. Odd not very common 5 each--------------------------------------------------------------------------------------------------------------------------------$20
Brass oil fitting on 109 block, have 2--------------------------------------------------------------------------------------------------------------------------------------------------------------------$20 ea
Bracket mounts on upper throttle body, for cruise, kick down, throttle cables. Have 2, 25525427 ---------------------------------------------------------------------$60 ea
Aluminum accessory bracket New, NOS, 25525338 -------------------------------------------------------------------------------------------------------------------------------------------$150
Bracket , metal shield, for 1987 rear pass cyl head. Not used in 1986-----------------------------------------------------------------------------------------------------------------$10 ea
Drain pipe, flex, stock turbo to block, 25525313------------------------------------------------------------------------------------------------------------------------------------------------- $75
Springs front grille 2 ea. set----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------$20 set
Hold down chrome bracket for heater assembly at T body area--------------------------------------------------------------------------------------------------------------------------$20
Trans servo cover 8635694 Lester 1987--------------------------------------------------------------------------------------------------------------------------------------------------------------$20
Fuel rail stock 86/87 used -----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------$85
Rear tail pipe hangers L and R , 2 pieces each side 25518591,,528. NO RUST--------------------------------------------------------------------------------------------------- $60 all
Kirban power antenna cable repair kit------------------------------------------------------------------------------------------------------------------------------------------------------------------$40
PUI Visors pair , medium gray 78GVC00--------------------------------------------------------------------------------------------------------------------------------------------------------------$50
Power antenna mast assembly NOS, complete NOT G BODY. appears to be Buick Regal 1991-94--------------------------------------------------------------------$40
Speakers Jensen JSM301 rear deck shelf-----------------------------------------------------------------------------------------------------------------------------------------------------------$20
Speakers Blaupunkt RL 3524, new in box older model, pair---------------------------------------------------------------------------------------------------------------------------------$20
Speakers Pioneer TS-A4103 new in box older model. pair, 4 x 10-----------------------------------------------------------------------------------------------------------------------$20
Speakers Rockford Fosgate HPC 1369 used w/ 4 x 10 adapters -----------------------------------------------------------------------------------------------------------------------$40
Austin Kendall
