Adapting a chevy transmission Q's
22lbChevelle
Looking to adapt my 2004 4l80e to the LC2.
Obviously I need the bellhousing adapter plate and washers between the flexplate and converter.
How about a converter to crank spacer? Something that will allow the converter to seat itself on the rear of the crank.
How about longer alignment dowels?
Just get hold of Lonnie. I believe he's making bolt on bellhousings so you don't have to do what you're trying to do.:)
Thanks Charlief. I suspect you are referring to the kind where I take a cut off wheel to my case and bolt a bellhousing to the front pump? I will contact him and consider this approach.
Otherwise, does anyone have any comments on my originally posted questions?
