Mar 6, 2011 #1 L LOT Member Joined Oct 15, 2009 Messages 1,030 I will be needing a cam button that the austempered cams require. The one you shim. Where would I be able to purchase one ? Thanks
Mar 6, 2011 #2 F forcefed3.8's Buckeye Bullet Joined May 26, 2002 Messages 3,845 Weber and Full Throttle have them.
Mar 8, 2011 #3 N NCTURBOS Gettin' back in action!! Staff member Joined May 26, 2001 Messages 3,951 Lee, I get mine from DLS. K.
Mar 8, 2011 #4 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 Summit has them in stock also COMP Cams 269 - COMP Cams Cam Buttons - Overview - SummitRacing.com THe pic is a little different than actual part but this is the right one.
Mar 8, 2011 #5 L LOT Member Joined Oct 15, 2009 Messages 1,030 That's what I'm looking for. Thank you very much.
Mar 8, 2011 #6 G GSTOY Member Joined Feb 12, 2008 Messages 553 I also think TA Performance has them...
Mar 8, 2011 #7 D DR BOOST Technical advisor Joined Aug 2, 2001 Messages 2,662 if its for a billet roller cam doesnt DLS make them for everyone else? give dan a call, he'll set you up with the right one.
