This evening i hooked up my alky kit. And plumbed my vac lines for my boost controller. (Adjustable Air Valve). Now to my understanding all i am trying to do is restict the vacuum to the wastegate actuator?....the more restriction the less air to the wastegate meaning more boost. Now if this is correct should the valve be just before the wastegate actuator vac, or should it restrict the pcv, vac block, and the actuator?
