Adjustable Boost Control
jessecool
This evening i hooked up my alky kit. And plumbed my vac lines for my boost controller. (Adjustable Air Valve). Now to my understanding all i am trying to do is restict the vacuum to the wastegate actuator?....the more restriction the less air to the wastegate meaning more boost. Now if this is correct should the valve be just before the wastegate actuator vac, or should it restrict the pcv, vac block, and the actuator?
Got it...hooked it up just before the wastegate act. line...works awesome. My car is running great now. Pushin around 15-17lbs clean on 93oct in like 80 degree weather, havent even tried to pull more. .Now to start adjusting alky and actuator rod. Thanks
