SignUp Now!haha....an alky kit is def. on the to-do list. Back to my question though, if I was to purchase only the RJC controller would i be able to adjust boost w/ that even if I have the stock, non-adjustable wastegate??
Yes.sweet...just to clarify this again....you can adjust boost w/ the RJC controller even if you have the stock non adj. wastegate right??
No- because the actuator doesn't move until the controller valve opens at his chosen PSI setting.But wont you be limited to a max boost of where the stock WGA is set at??
You could adjust boost with the wastegate rod if you want. Don't know about others but I only went to a mbc because I maxed my wastegate rod out and didn't achieve the boost I wanted. I didn't go with wn hd rod because burning my knuckles was becoming a pita.![]()
