Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
I have an adjustable actuator rod on my Turbonetics 6465. Using the stock boost solenoid, TT chip and rod, I have the boost set at 20psi. I understand with this setup, the rod is the final boost setting. With a manual boost controller (non bleed off style) will the rod setting be the final boost setting or will the manual boost controller over ride the rod setting? I'm trying out a Grimmspeed mbc. It definitely spools the turbo faster than the stock solenoid system. According to them, one full turn equals about 4psi. I turned it down 41/2 full turns and am seeing 20psi. If I keep turning it down, will I gain more boost or will I have to readjust the rod and reset the mbc to open at the new boost setting? Thanks!
