I put together an alchy system but have some questions regarding the pressure output. When I hit my purge button the pressure jumps to 125 psi and then cycles back / forth at about 90-110 psi, this is with one M10 nozzle. I am also using the Shurflo pump.
Do these pressures look ok? Should I just leave the pump cycle? Thanks
paul
paul
