Just replaced my stock smoking smashed turbo with another stock, non smoking non smashed turbo. While I was at it I ported my elbow , installed a billet inlet bell and a ported and matched compressor housing, and ported the inlet to the IC. I also installed an adjustable wategate actuator. When I set it up on my bench I tried to match the arm length to the factory one. I must be a tad short as on my test drive I could see boost wanting to pass the 15psi mark that I have the chip at. I know I am knock free at 15psi in 3rd gear and I did not allow it to go past that mark.
My question is how do I adjust my wastegate actuator? Can I just turn the rod that goes into the diaphragm. Or do I have to undo that little clip and turn the end? Thank you in advance for the help.
