G GW2 Member Joined May 29, 2009 Aug 6, 2010 #1 Which way is up in psi and which way is down, and its 1 full turn per pound of boost correct?
J Just a Six?? OK! Who Farted?? Joined Jul 4, 2003 Aug 6, 2010 #2 Shorten it to raise boost About 1 turn is 1 lb. Have you read here at all? www.vortexbuick-etc.com It should be mandatory reading. Also being in Ontario go to the other site with an "S" on the end & check Toronto serction. 100 guys from all over hang there.
G GW2 Member Joined May 29, 2009 Aug 6, 2010 #3 ya i know about the other site. not as active as this one though. and i have read that in the past but havent for probably a year. need a re-read. Thanks for the help!
G GW2 Member Joined May 29, 2009 Aug 6, 2010 #4 Oh and you missed the s on the end of buicks in your link. just letting you know.
