SignUp Now!Originally posted by CSJTA
Are there any real advantages of running either, Alpha N/Speed Density? Just wondering, I see most people run SD, but why not more AN? Thanks for your thoughts, Chris.
Alpha-N + turbo = engine parts on ground.
Originally posted by Craig Smith
It is definitely a simpler process within the ECU while in Alpha-N mode, but to call it "crude" makes no sense to me.
Speed/Density definitely has more to offer in terms of street manners and tuning resolution.
As I stated, my engine makes no vacuum except when I lift at the top end of the track. I have a 15:1 alcohol burner with a camshaft with over 290 degrees of duration at .050" lift. Speed/density is great for engines that create a vacuum signal to work with. On an engine like mine Alpha-N is really the only way to get the car to idle and drive around well without loading up.
The trick is at part throttle. At WOT it's going to be fairly repeatable, but at part throttle, you never know where the boost level will be and there isn't a way (at least with the FAST, which is all I am speaking of) to accomodate this in Alpha-N. This could certainly allow for a situation where you would quickly lean out as the turbo started coming up but no additional fuel is coming in.
Thanks everyone for your thoughts, now one more question, do you still get Wideband O2 correction while running in AlphaN?
All my experience thus far indicates that maintaining the same a/f ratio as the air changes makes a bracket car less consistent than a variation in the a/f ratio will.
