RealFastV6
Plays with Trucks
- May 26, 2001
Originally posted by strikeeagle
I didn't mean as compared to a stock turbo running way off its design point. I meant that a stock turbo running at its design point will produce a cooler charge that a larger turbo running well off its design point. Evidence the compressor curves. Lower efficiency = more heat.
Of course. Nobody is saying bolt a T88 with a Stage 3 turbine so you can spool it on a stock motor. The stock turbo isn't in its in its peak efficiency at 18-19psi. This was a hypothetical question that started this thread, simply... will a slightly larger turbo add any benfit on pump gas.
Answer, yes.
So far as surge goes, for a centrifugal compressor stage, surge is the condition where there is insufficient flow for the particular head (boost, if you like). If the compressor associated with a large turbo can't deliver sufficient flow into the motor for the boost you're running, trust me, it will surge.
Right.
However, most of the standard GN turbos that bolt up (TE44, T66/P, T70/P/Q, T62,P,S3) are speced out to run 25-29psi. Going a size up on the turbine wheel without going a size up on the compressor will free up some flow and some power. Again, surge shouldn't be a concern since you'll see 21psi MAX on pump gas anyhow. If you speced out a turbo to be in its peak efficiency at around 21#, and then tried to run 27psi with it, THEN it'll surge like you said.
Also, I think we're confusing the relationship of turbine and compressor. It is the expansion of hot exhaust gases across the turbine which provides the power to drive the compressor, not the other way around.
Of course. Where did I say otherwise? But just because the turbine spins the compressor doesn't mean the turbine can't be choking the motor and in-turn the compressor also.
[/B]A bigger turbine wheel and cover are wonderful from a pressure drop point of view, but not if you need a 4000 stall to get the motor to make enough air to drive it to design speed. [/B]
Again, nobodys talking about bolting a T88 onto a stock motor here. The question was simply this... will a slightly larger turbo add any benfit on pump gas...
The answer is yes.
Back under my dash...
