Steve Wood
- Jul 18, 2001
Originally posted by RealFastV6
CT... you guys all wonder why we pay so much for gas... well, its Magical gas.![]()
Geez, we make all the damn gas down here and send the good stuff to CT?
SignUp Now!Originally posted by RealFastV6
Originally posted by Berman
Blow-off valve. Nuff sed.
Originally posted by Steve Wood
Geez, we make all the damn gas down here and send the good stuff to CT?![]()
Originally posted by Wht87T
I'm only getting 16-17psi on 93 octane, with a TE61 P-Trim, Cotton FMIC, and a Vigilate "0" pump. How are guys with similiar combos running 20-21psi on pump gas?????? That totally contradicts everything that I know about these cars. Will someone let in on the secret???
Actually, the blow off valve works better for disposing of the pent up boost that kicks back against the compressor when one lifts off the throttle than they do for eliminating compressor surge which is a completely different animal.
Originally posted by GNSCOTT
I know i gave at least4 other board members a ride in the car to prove it to them because i thought there was something wrong with the car. I changed knock sensors, boost guages and did everything i could to make it knock. Finally at 26 psi it began to detonate, and upping the timing made it knock like crazy.
CLIFF NOTES:
A stock turbo putting out 18-19 psi into a motor with basic upgrades (dp, exhaust, mafpipe, filter, etc) is out of its peak efficiency.
A larger turbo would net REAL LIFE horsepower gains without turning up the boost.
The Horsepower gains would come from...
a) A cooler intake charge due to a more thermally efficient compressor.
b) Greater exhaust gas scavenging in the cylinders.
The End.
I never said that I was trying it with the same set up. FYI, the TE45A from John Craig has a 66mm wheel in it. It is not similar to a 63 from PTE. Not even close unless PTE is installing larger compressor wheels now. This turbo I have will be going on another engine with ported heads, 72lb injectors, ME chip and will be installing a mild cam and a 9x11 convertor. I know what I am doing and when I have a problem, I ask questions.Originally posted by Richard Inglett
GNVAIR,
Please do yourself a favor. Don't even try. Although it is difficult to say for sure, I believe the TE45A is equivalent to a stealth 63. It is a big turbo (at least for most us). It will not perform with same injectors and programming that works well with a TA49. If your lucky, all you'll do is blow a head gasket but more than likely, you'll spit out your crankshaft.
Strikeeagle's comment about compressor curves is valid and Steve Wood's comment about cylinder pressures nails it. First, some of the larger turbos are actually less efficient than some smaller ones. This equates to more recirculation in the turbo and thus, more heat. Second, CFM is a huge factor on cylinder pressure. With a high enough flowrate, 15 psig can be more harmful than 25 psig from a smaller turbo. Especially with 93 octane gas.
There is more to it than just swapping from a smaller to a larger turbo. Your TA49 swap was a definate upgrade to a better turbo and more than likely, a more efficient turbo. Your next swap is more serious and will demand larger injectors and programming to make it work.
One last comment. The larger the turbo gets, the more important porting & exhaust become. With stock unported heads and assuming 85 percent efficiency, our engines can only move about 195 cubic inches of air every two revolutions. Trying to force more air than this will cause surging. Rarely an issue at higher rpm's but some cars will shake & shudder at low rpm's (ex. 2000 rpm @ 5 psig). Review of a compressor curve makes it easy to see why. The operating point will be to the left of the surge limit line. Higher rpm's will usually keep the turbo to the right side of this line but it doesn't necessarily correspond to an efficient operating point. In short, bigger turbo is not an automatic increase in efficiency and therfore does not always mean cooler air temperatures. You have to have the combo matched and have plenty of fuel. Otherwise, you will learn the hard way.
