90c1500tbi
- Feb 19, 2004
I've been viewing this site for a while, but this is my first post. I'm a FAST newbie, and this site has been a big help!
I'm having trouble getting rid of a stumble when I open the throttle quickly. Opening at a slow to moderate rate is smooth, but when I punch it (from idle or at slow speeds), the engine nearly dies until I back off. Logs indicate a lean condition, so I've increased AE vs TPS Rate at the higher rates. It got better, but now I'm maxed out at 4.0 mS @ 15 cts/4mS and the problem is still there. My AE vs TPS Position is 100% until 21, slopes down to -20% at 43 and levels off. My TPS position is 17 at idle, 93 at full throttle. Right now, I have the AE vs MAP Rate at zero because I read that it wasn't really necesary for a mild naturally aspiriated engine. Could it be that the two large fuel injectors I have in the 2-bbl TBI (see signature) can't keep up with the demand? Do I need to change the injector opening time setting (1.0 mS right now)? Since there are two 90 lb/hr injectors for eight cylinders, I put 22.5 lb/hr (90*2/8) for the injector flow rate in the system config. Is this correct? Do I need to add AE vs MAP?
Any advice would be greatly appreciated!
