T66Typhoon
SUV Pimp
- Feb 2, 2003
I need some clarification on the AE vs. TPS Position
I am confused as to what this telling me.
I am ASSuming that it means that if I am at a given throttle position it will not allow as much AE added from the AE vs. TPS Rate table.. is this correct.
What I am seeing is that if I am already at constant throttle at 35% and then go to 75%, I am not going to need as much fuel as if I was going from 21% (idle) to 75%.
Correct?
So I this is how I have it setup.... the Typhoon has a T66 on it with 83# injectors. Just having some tip in stumbles and wondering if there is something here I should be worried about.. my problems seem to be right off idle between 1900 and 2100 RPM.
Sorry if pics are not to be used on this forum.. but a pic is worth a 1000 words as they say. I will delete it immediately if someone tells me they are forbidden.
Correct?
