GNcollectables
- Dec 12, 2005
aeromotive F/P system:
a1000 pump, filter & 13301 adjustable regulator plus #10 braided hose & fittings! connect 1 end to your tank, the other end up to the regulator and you're ready to rock!
gas tank (or fuel cell) #10 line: 45 degree fitting on tank side & straight fitting on other side that leads into filter, 6' long hose.
#10 fitting into filter which is connected to pump via #10 fitting, then another #10 fitting out.
second line: #10 straight fitting, 8' long braided hose, 90 degree swivel on regulator end.
you'll need to get a #10 to #6 reducer to attach to regulator. then connect up your own carb line to the front. theres a #6 fitting on the bottom of the regulator for a return line. theres an extra outlet on the side for a fuel pressure gauge or whatever.
ready to go used but awesome working system to make your TR rock! $450 shipped to your door (in U.S.).
Comp Cams race (or deadly street) cam! 224 224 (@ .050) Turbo Buick Billet Roller Camshaft, 556 lift! brand new in box with cam card never used! You want serious performance? This is it! $380 shipped to your door (in U.S.). {save $65+ from below site!}
as shown here {replace XXX with: net):
weberracing.XXX/p542/224-224-Turbo-Buick-Billet-Roller-Camshaft/product_info.html
see pics below!
Hurst Roll Control, line lock, new in box never used, $90 shipped to your door (in U.S.).
see pics below!
