Factory and aftermarket parts for sale
deleonl
N.S.D.Q
Had some extra time to put a list together of parts I have in storage. All parts are plus shipping and paypal fees.
Let me know if you have any questions.
Factory speedo rear housing have three - $5 each
Factory support assembly cushion part number 348080 have four - $50 for all four
Factory inside door handle new - $10
Factory speedo cable new - $15
Factory turbo drain tube - $40
Factory 3.8 SFI turbo emblem new - $50
Factory window switch have two new - $10 each
Factory new third brake light assembly - $125
Factory outside door handles right and left new - $20 for both
Factory brake light switch new - $5
Factory PCV valve AC Delco new have eight of them - $12 each
Factory O2 sensor AC Delco new - $20
Factory wheel cap have one new - $35
Factory wheel cap have one used - $20
Factory down pipe elbow for turbo - $25
Factory MAF used - $20
Factory radiator fan - $50
Factory throttle body - $50
Factory turbo cover - $75
Factory fuel hose set new - $10
Factory 87 GN badges used - $50
Factory lug nuts only five new - $10
Factory front swaybar – $40
Factory rear lower upper control arms - $40
Factory glove box grey new - $50
Factory radio bezel used (one broken clip) - $20
Factory radio bezel new - $50
Factory speedo glass cover new - $25
Factory speedo dash gauge used – make offer
Factory plenum - $75
Factory light bulbs for speedo gauge – make offer
Factory AC switch knobs have three - $10 for all three
Factory windshield wiper tank used – make offer
Factory ash tray - $5
Factory fuel rail with vacuum lines and aftermarket fuel regulator - $150
Factory fuel rail - $40
Factory AC heat shield - $50
Power steering pump - $50
Alternator with pulley - $50
After market MAF sensor and four-inch pipe - $100
Aftermarket turbo believe it to be a TA49 min shaft play - $400
Upper radiator hose - $25
2 x Coil packs with wires and brackets - $150 each
Chrome MAF 3 inch pipe - $80
Upper intercooler chrome pipe $80
Aftermarket Boost gauge with a-piller pod - $50
Aftermarket water/volt gauges with dual pod - $50
Innovate Motorsports wide band 3844-MTX-L used - $100
Kirban Performance LED dashlight kit used - $60
Spark plug wires Thundervolt 50 used - $50
Turbonetics boost controller used - $50
Camshaft position sensor part number 255169153172 new - $200
2 x Four inch MAF couplers new - $10 each
Knock sensor new - $10
Driver side mirror new - $50
Ash tray panel switch (trans fan and line lock) - $40
GN aftermarket lug nuts have ten - $10 for all ten
Bumper filler fiberglass passenger side - $75
Holley black electric fuel pump with AN fittings - $100
Passenger side visor t-top panel - $10
Center t-top panel have two - $10 each
Lower steering wheel panel - $10
Water heater value new - $25
HVAC blower control switch - $10
AC Delco crank shaft sensor bracket - $8
ECM memory cable from Casper’s electronics - $10
UMI Performance rear end housing bushings 3000-R new - $30
Mass Airflow Sensor part number GM 15904068 new - $75
I will take the NOS NEW in the box outside door handles and NOS inside door handle please. PM Sent. Thank you.
Ill take the two window switches, driver side mirror, bottom black dash cover if not broken, speedo glass, and knock sensor. Let me know what you want for the cluster?
