TexasT
Texas, Where are you from
- Sep 10, 2002
Interested in the power steering pump.
Sent pm
Sent pm
SignUp Now!Kirban Performance LED dashlight kit used only have six of the seven lights - $40 is this still available?UPDATE as of 22 May 20
Parts that have been SOLD:
Factory inside door handle new - SOLD
Factory speedo cable new - SOLD
Factory 3.8 SFI turbo emblem new - SOLD
Factory new third brake light assembly - SOLD
Factory outside door handles right and left new - SOLD
Factory brake light switch new - SOLD
Factory O2 sensor AC Delco new - SOLD
Factory wheel cap have one new - SOLD
Factory fuel hose set new - SOLD
Factory 87 GN badges used - SOLD
Factory lug nuts only five new - SOLD
Factory glove box grey new - SOLD
Factory radio bezel new - SOLD
Factory speedo glass cover new - SOLD
Factory ash tray - SOLD
Factory coolant sensor new – SOLD
Factory turbo hose with y pipe kit - SOLD
Factory MAF used - SOLD
Aftermarket water/volt gauges with dual pod - SOLD
Turbonetics boost controller used - SOLD
Camshaft position sensor part number 255169153172 new - SOLD
NOS Knock sensor new - SOLD
Driver side mirror new - SOLD
Water heater value new - SOLD
AC Delco crank shaft sensor bracket - SOLD
ECM memory cable from Casper’s electronics – SOLD
Upper radiator hose – SOLD
Factory PCV valve AC Delco new have six of them - SOLD
Factory AC switch knobs have three - SOLD
Alternator with pulley – removed from list
After market MAF sensor and four-inch pipe - $100 (pending payment)
Spark plug wires Thundervolt 50 used - $50 (pending payment)
2 x Four inch MAF couplers new - SOLD
Ash tray panel switch (trans fan and line lock) - $40 (pending payment)
Bumper filler fiberglass passenger side – removed from list
Power steering pump - SOLD
2 x Coil packs - SOLD
Parts still available:
Factory speedo rear housing have three - $5 each
Factory plenum - $75
Factory support assembly cushion part number 348080 have four - $50 for all four
Factory turbo drain tube - $40
Factory window switch have new - $10
Factory wheel cap have one used - $20
Factory down pipe elbow for turbo - $25
Factory radiator fan - $50
Factory throttle body - $50
Factory turbo cover - $75
Factory front swaybar – $40
Factory rear lower upper control arms - $40
Factory radio bezel used (one broken clip) - $20
Factory speedo dash gauge used – make offer
Factory light bulbs for speedo gauge – make offer
Factory windshield wiper tank used – make offer
Factory fuel rail with vacuum lines and aftermarket fuel regulator - $150
Factory fuel rail - $40
Factory AC heat shield - $50
Spark plug wires Thundervolt 50 - $40
Aftermarket turbo believe it to be a TA49 min shaft play - $400
Chrome MAF 3 inch pipe - $80
Upper intercooler chrome pipe $80
Aftermarket Boost gauge with a-piller pod gauge turns seven different colors - $50
Innovate Motorsports wide band 3844-MTX-L used - $100
GN aftermarket lug nuts have ten - $10 for all ten
Holley black electric fuel pump with AN fittings - $100
Passenger side visor t-top panel - $10
Center t-top panel have two - $10 each
Lower steering wheel panel - $10
HVAC blower control switch - $10
UMI Performance rear end housing bushings 3000-R new - $30
Mass Airflow Sensor part number GM 15904068 new - $75
Are the dash lights still availabl?UPDATE as of 22 May 20
Ok, let me figure out shipping and get back with you.
