Aeromotive SS 100 micron filter
turbo96max
Guys,
I used this for about 5k miles looks new. Realized I should have been using a 40 micron. This comes with a new oring. Putting it out there incase someone can use it. I think i paid around 45 new hows 25 shipped ? OBO
Were you on E-85? Curious as to why the need to change, otherwise what do you think of the Aeromotive overall?
Yes i was on e85. changed bc the 100 micron is supposed to be used pre fuel pump for external systems as i found out after the fact. IIRC the soc on the walbros is 30-40 micron so post pump should be finer then 100 micron.
Not certain. I used it on an older style aeromotive.bigger than the newer style but generally they accept the same filter. I could be wrong but when i purchased it this is the one size they usually sell.
