Aerospace Components brakes, 6665 turbo
forcefed3.8's
Buckeye Bullet
Aerospace Components front drag brakes, mounted on modified factory spindles. These have well under 100 passes on them. $500 shipped
Precision turbo 6665 cast wheel turbo, new never used, high 9 sec capable, same as a TE45a but with the newer high flow 10 blade turbine. $650 shipped
Pics
Interested in the turbo how long have you had it and will a stock torque converter work OK with it?
It will be a pig with a stock converter. This really needs an engine with heads and a cam and a real converter to spool good on the street.
Ok I will get with you as soon as I take it off the car sometime this week unless you need it sooner.
