AFCO 30271 1978-88 GM Metric Improved Geometry Steering Center Link
~JM~
Wrinkled Member
Anyone familiar with this part?
How does it compare to using the original center link & an aftermarket tie rod bump steer kit?
Will it perform as well or better with a tie rod that has a ball joint at each end, vs. a Heim joint? Does the spindle end of the tie rod still need to be mounted lower?
I'm thinking a ball joint would be preferable to a Heim joint for street driver longevity.
Found a few reviews that state the left hand turning range is reduced.
I was considering this center link until I called them.
The improvement for this one was so it would turn better - left only.
