Started a new thread on the same topic...
Installed new engine...used a reportedly new crank sensor, a slightly used cam sensor (both looked new), a new Casper cam sensor cap, and the coil and module from my original engine...replacement coil and original 40k mile module.
After new engine install it started immediately on first try. Drove around a mile or two let idle for a while and shut it off...would not restart. Let it sit for about 30 minutes and it started again. Repeated the same a few days later. Checked for crank sensor gap...it was OK, checked to insure cam sensor would not rotate...it didn't, and confirmed the module was correctly attached to the coil (it had to be because I didn't disturb it when removed from original engine).
Obtained NOID light but engine started at each attempt...then went on a one month vacation. Got back last Thursday and today I looked at it again.
Today started engine and let it idle for 10-15 minutes...shut it off and installed NOID light. Attempted to restart and it did not start, and no NOID light i.e. no injector pulse. Checked for spark...no spark either.
The diagnosis is???
Thanks, Bob
The diagnosis is???
Thanks, Bob
