getchasum
MISSING 2 CYLINDERS???
- May 23, 2002
Would the preferred set up be to series an aftermarket trans cooler with the stock cooler or just use the aftermarket as a stand alone. I’ve just finished an engine freshen up that had a thrust bearing failure and I never really determined the cause. I was thinking that maybe I’m having excessive line pressure form having the two coolers series prior. Where should return line psi be and is this a possible restriction?
Stock original trans w/ Bruce's shift kit and a 9" billet AC, Any Opinions???
